robfantini
May 19, 2017Aspirant
'static manal lag' and hash mode to use on L3 switch
Hello
Our main switch is a gsm7252sv2 . We have lags set up to pfsense and 10+ virtual machine hosts.
for a seconday network we purchased a JGS524PE which has ' Static Manual LAGS only' .
My questions are :
On the L3 switch: which 'Hash Mode' is compatable ?
What other setting should be used at LAG Configuration?
best regards, Roberto
Hi Roberto
Because Web Managed Plus switches like JGS524E only do static LAG with MAC address parsing, on your Fully Managed switch (M5300 - GSM7352S), you should create a LAG and use static mode with our default hashing:
- Static Mode = ENABLED
- Hash Mode = 3 - Source/Dest MAC, VLAN, ETH
- LaurentMaNETGEAR Expert
Hi Roberto
- robfantiniAspirant
Thank you for the solution . kind regards, roberto .
