dgoodliffe's avatar
dgoodliffe
Follower
Nov 17, 2015
Switch error message
Hi
UNKN[196193840]: dtl_end.c(179) 7090 %% DTL avl mac delete error!
Can anyone explain what this error above is about. I have googled it but cannot find the answer.
Kind Regards
Mr. Donald Goodliffe
Network Manager
Impington Village College
New Road, Impington,
Cambridgeshire, CB24 9LX
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi dgoodliffe,
    Welcome to the community!
    It seems you have already contacted NETGEAR Support about your concern.  Let us isolate the problem.  Kindly answer the questions below:
    a. On what specific switch model/s are you seeing the error?
    b. Did you modify the configuration of the switch/es prior in seeing the error? If yes, what are the changes you did on the settings of the switch/es?
    c. Is the switch/es still working fine while the error is present?
    I look forward to your response.
    DaneA
    NETGEAR Community Team
  • The message was reported by DTL task.  It is normal for it to report those.. just means that it could not delete mac.  More of informational rather than actual error.  To understand what caused it.. you will need to understand object it was reported under.. MAC based vlan, protected ports..etc could be anything can't really say unless I see more of log before and after... since your post is missing the entire before and after messages...
ProSupport for Business
