aescher
Jun 10, 2016Follower
Switch with PoE based on time table
Dear all
I am looking for a Switch that allows PoE based on timetable (e.g. switch off at night).
Any recommendations? I need in total 16 Ports, thereoff 4 should be PoE equipped.
Regards and thanks a lot :-)
Andreas
- JohnRoNETGEAR Employee Retired
Hello aescher,
Welcome to the community!
As of the moment, we do not have a PoE switch that has a PoE timetable settings or PoE scheduling. What we have right now on our Smart Switch series with PoE are the following features:
PoE Port Configuration:
- Admin mode
- Priority Level
- Class
- Output Voltage, Current, and Power
- Power Limit
- Status
Such features are available here (see page 46-48). You may also want to see this model.
I hope this helps.
Thanks,
Hi aescher,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
