jrk1977
Nov 08, 2017Aspirant
SYSLOG not received in manageengine eventlog analyzer
System Description -M4300-28G ProSAFE 24-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ System Software Version "12.0.2.17" DearTeam, We have configure the Vlan and its working fine. vlan da...
DaneA
Nov 12, 2017NETGEAR Employee Retired
Hi jrk1977,
Welcome to the community! :)
By default, VLAN 1 is used as source interface. Have you tried to change the source interface to either of the following: Routing Interface, Routing VLAN, Routing loopback interface, Tunnel interface or Service port and check if the syslogs will show up?
From the syslog server, are you able to get replies when you ping the IP Address of all VLANs?
Also, try to change the Severity Filter from Alert to Debug and check if the syslogs will show up? As reference, kindly read pages 428-429 of the M4300 Series software administration manual here about Logging Hosts.
Also, kindly read pages 631-634 of the M4300 Series user manual here about Syslog and Syslog Host Settings.
DaneA
NETGEAR Community Team
