jrk1977
Nov 08, 2017Aspirant
SYSLOG not received in manageengine eventlog analyzer
System Description -M4300-28G ProSAFE 24-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ System Software Version "12.0.2.17" DearTeam, We have configure the Vlan and its working fine. vlan da...
DaneA
Nov 16, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
NETGEAR Community Team
jrk1977
Nov 16, 2017Aspirant
Hi Thanks for your Reply,
That helps me ya lot
By Changing the Severity Filter from Alert to Debug its solves the problem.
Now My Logs Server receiving the Logs from M4300 and Edge M4100
Thanks You So much...
- DaneANov 19, 2017NETGEAR Employee Retired
Thanks for the update! I'm glad to know that you are now receiving logs from the M4300 and M4100 switches. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
