oheli1
Mar 23, 2021Aspirant
Tagging/Untagging of Ports connected to ESXi-Host and APs (WAC720)
Hello together, Currently we have some really bad issues: the network is not stable an some clients got the wrong IP-Adresses from a different VLAN. To eliminate setting-failures I couldn't find any...
schumaku
Mar 23, 2021Guru - Experienced User
Eli,
Here some simple guidelines and check points:
1. Where a single adapter/computer should be connected a defined VLAN eg. 1234, only the VLAN 1234 is [U]ntagged on this port, and logically also the PVID must be 1234 (defining the VLAN ID untagged frames flowing to the switch will be assigned to) - that makes up an access port. No other VLAN must be be associated to this port or LAG, neither untagged nor tagged.
2. Everywhere where you have multiple VLANs over a connection or a LAG (switch stack, switch interconnection, ESXi hosts, wireless access points, ....) - a trunk - all VLAN must be [T]agged. Only _one_ VLAN can be run untagged and again the PVID must be set to the same VLAN ID.
Time to review everything, and clean out the mess which is (sorry - obvious) in place there. All VLAN untagged on a switch interconnection is definitively wrong! You will end with wild interconnection of what re supposed to be independent networks. It's difficult to provide a general standard which VLAN should be run untagged. Sometimes, you can have devices with special requirements or limitations. Write down _exactly_ what you want to achieve, and how the switch stack, and other trunk connections are supposed to be configured.
Have fun troubleshooting and clean-out the spaghetti network!
-Kurt
oheli1
Hello Kurt,
thanks for your reply.
This was exactly what I've done. I made an excel-sheet and copied all seetings of every single port from our 6 swiches in that sheet.
(At netgear GUI this is quite tedious and cumbersome)
How to configure a access-port is clear. How to configure a trunkport is also basically clear.
But my questions are still not clear to me.
1) WC7600
Here are my settings for the controller and one AP
I tagged all my needed VLans (20, 110, 150)
What are the correct settings in this scenario for PVID and (U)ntagged membership?
a) PVID-ID_100 & (U)tagged membership_100
b) PVID-ID_1 & (U)ntagged membership_1
c) both possible
As I understood you correctly, both would be possible, right?
2) Stacking ports: Here are screenshoots of two VLAN-IDs and the PVID settings
Same here, what would be the right settings?
a) Membership: VLAN_20 (and all used VLANs) set to (T)agged & VLAN_1 also set to (T) & VLAN_100 stay (U)ntagged & PVID & changing to ID_100
b) Membership: VLAN_20 (and all used VLANs) set to (T)agged & VLAN_100 also set to (T) & VLAN_1 stay (U)ntagged & PVID & changing to ID_1
c) both is working
Additional question: Is the wrong setting the reason why the "current PVID" is set to "0"?
I hope I'm not annoying :smileyfrustrated:
- Jul 18, 2017Retired_Member
