oheli1
Apr 22, 2021Aspirant
Tagging/Untagging stacking-ports
Hello together, I still got no answer on my questions, so I will ask again in this new discussion: How must these specific stacking-ports be marked? a) Currently I have U(ntagged) all used VL...
JohnC_V
May 03, 2021NETGEAR Employee Retired
Welcome to our community! :)
Stacking port is neither tagged or untagged. It does not affect the VLANs on your network because this will only make your 2 switches as one.
May I know what seems to be the problem?
John
NETGEAR Community Team
oheli1
May 10, 2021Aspirant
Hi John,
thank you for your support.
Our problem is, that we have a very unstable WLAN-Network in our School.
I already changed all WNDAP 360 into WAC720 (Controller is a WC7600v2).
Sometimes the connection to the devices is very fast (as i should be) sometimes I disable and enable WLAN on (Mac/iPhones/Thinkpads ..) many times. And if I'm lucky, it connects to the desired WLAN-ID.
Therefore I startet to check all settings (also these which have been set years ago).
I didn't find any tipps in the documentation about this topic.
One more question: what about PVID
Should it set to default (ID1) or should it also be kept empty?
Best regards
Eli
