so_hemanth's avatar
so_hemanth
TFTP enable
How copy the running config from switch to TFTP server or vice versa how to push the config from tftp server to switch in CLI mode ( I am searching for commands)..?
Help me
Thank you in advance..!!
  • so_hemanth,
    Welcome to the community! :)
    You will need to create a script of your running configuration:
    (GSM7224P) # show running-config running-config.scr
    Then, upload the running configuration script from the GSM7224P switch to the TFTP server:
    (GSM7224P) #copy nvram: script running-config.scr tftp://<TFTP server IP address>/running-config.scr
    If you want to download the running configuration script from the TFTP server to the GSM7224P switch:
    (GSM7224P) #copy tftp://<TFTP server IP address>/running-config.scr nvram: script running-config.scr
    For more information, kindly read the following:
    Pages 269-271 of the M4100 Software Administration Manual here.
    Pages 371-374 of the M4100 CLI Manual here.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    so_hemanth,
    DaneA
    • so_hemanth's avatar
      so_hemanth
      Dear DaneA,
      Thank you for the Suggetion.....!!
      Commands are working..
      With best Regards
      Hemanth.S
ProSupport for Business
