DavidHuen's avatar
DavidHuen
The SNMP service is occasionally unavailable
Hi all,
My customer is currently facing occasional SNMP unavailability. I have checked uptime ot the switch and found that CPU and memory are normal. After reset snmp, the snmp service resumed. However, after a period of time, this issue will occur again, and it is still unclear about the time interval and trggering conditions, which may be a software bug.
May I ask if anyone else has encountered the same problem and has a solution? Thank you.
Below information is the switch parameters:
[Product Name]
NETGEAR 48-Port Gigabit PoE+ Smart Managed Pro Switch with 4 SFP Ports (GS752TPv2)
[Model Name]
GS752TPv2
[Boot Version]
1.0.0.5
[Software Version]
6.0.3.3
1 Reply
  • schumaku's avatar
    schumaku
    It's not about the service becoming U/S - it dos stop responing for reasons...
    Netgear smart managed switches have built-in CPU protection mechanisms that can and do limit aggressive or recursive SNMP polling, which is sometimes flagged or dropped if mistaken for anomalous or resource-intensive traffic.
    SNMP Polling Limitations & Security
    • CPU Protection: Netgear switches restrict mass, recursive OID (Object Identifier) polling to prevent high CPU loads or lockups from monitoring tools.
    • Rate Limiting: High-frequency polling intervals (such as querying every few seconds across hundreds of ports) can overwhelm the limited management CPU on Smart Managed switches.
    • Mitigation: Increase polling intervals (e.g., to 60 seconds or more) and use targeted OIDs rather than bulk walk commands.
    Intrusion Prevention and Management
    Lack of Deep IPS: Netgear smart managed switches operate at Layer 2/3 and do not feature full inline Intrusion Prevention Systems (IPS) or deep packet inspection (DPI) like dedicated firewalls or UTM appliances.
    Built-in Attack Mitigation: They offer basic security features such as DoS prevention, Access Control Lists (ACLs), and port security to drop malformed packets or limit unauthorized management access.
    Interaction: Heavy SNMP polling combined with security features like DoS or storm control can occasionally cause the switch management interface to become unresponsive or drop ICMP/SNMP packets if CPU thresholds are crossed.
    Intrusion Prevention & Security Triggers
    While the switch does not feature active inline Intrusion Prevention (IPS), it utilizes specific built-in defensive configurations that can flag heavy SNMP traffic as a threat:
    • Denial of Service (DoS) Protection: If you have enabled global DoS protection in the management portal under Security > Management Security, the switch tracks high packet rates destined for its own IP address. Aggressive, multithreaded polling can easily look like a management-plane UDP flood or a brute-force sweep, causing the switch to drop the polling packets entirely.
    • Auto-Protection Engine (Storm Control): If your monitoring server sits on a port where Broadcast/Multicast/Unknown Unicast Storm Control is strictly limited, high bursts of discovery packets can result in the switch rate-limiting or blocking the monitoring port altogether.
    Have no such switch at hand, so please check
    Management > Denial of Service > Auto-DOS Configuration
    Security > Traffic Control
    Better, more promising with less effort? Start here:
    Optimize Your Network Management System (NMS)
    If you prefer not to lower the switch’s security posture, you can adapt your monitoring software to respect the low-power microcontrollers inside Smart Managed units:
    • Increase Polling Intervals: Switch from 1-minute intervals to a minimum of 3 to 5 minutes.
      Restrict OID Scope: Stop bulk-walking the entire MIB tree. Explicitly configure the pollers to only query essential OIDs (like specific port traffic statistics) to keep CPU overhead minimized.
    • Implement a Polling Delay: Set a small delay (e.g., 20–50ms) between consecutive OID requests in your monitoring profile to prevent packet bursts.
ProSupport for Business
