some's avatar
some
Initiate
Apr 25, 2018
Throughput Speed
I am having an issue with through-put speed. We purcahsed our switch back in 2014. The switch has been working great every since. Recently we upgraded our ISP speed to a 300meg by 20meg connection. P...
  • TheEther's avatar
    Apr 25, 2018
    A 90 Mbps transfer rate strongly suggests that at least one of the links is running at 100 Mbps. You should check your cables and confirm that the all ports have negotiated to operate at 1 Gbps.
ProSupport for Business
