dgonsi
May 23, 2017Follower
Transceiver sonnet SFP+ SR compatible M4300
Hi, i want to know if this SFP+ Short-Range transceiver: Sonnet G10E-SFP-SR
https://www.sonnetstore.com/collections/network-adapters/products/sfpmodule-shortrange
is compatible with the Switch: Netgear M4300-12x12F
I would like to connect the sfp+ transceiver directly in 10GBase-X SFP+ ports of netgear switch
replacing AXM761
Does anyone knows if it is compatible and reliable?
some other better module?
thank u!
regards to community
- Acorn123Aspirant
i suggest you choose this one https://www.cozlink.com/fiber-optic-transceivers-c322-324/product-62843.html
It is cheaper a lot.
Im sure it can be compatible with your switch:Netgear M4300-12X12F.
Best regards,
Acorn
- LaurentMaNETGEAR Expert
In our M4300 documentation, we specify NETGEAR-only modules. Why? Because NETGEAR designs and tests its switch products for use with genuine NETGEAR Modules only. The use of third-party modules may result in reduced network performance and reliability, such as packet loss and connectivity issues. While the use of third-party Modules does not affect the NETGEAR switch's warranty, NETGEAR may not provide technical support for networking problems it determines are caused by third-party Modules only. In your situation, cheap modules on the internet don't inspire me. I trust reliability is most important to me, perfect interop, seamless support by NETGEAR, etc.
To answer your question, we strive to offer maximum compatibility with standard based, high quality third-party modules, when it's possible. We don't claim universal support. I'd personnally be careful with lowest cost 10G optics.
Acorn123, would you let us know which NETGEAR 10G switch you are using?
- zx10guyAspirant
I'm resurrecting this thread about optics. I would also like to know if Netgear has a vendor lockout embedded in their firmware to exclude the use of other vendor optics/DAC (Twinax) cabling. I understand the discussion about having validated optics which are specfic to the manufacturer of the switch. But I have quite a few quality Dell Networking optics, some Cisco optics, and a large quantity of Dell Networking/Cisco DAC cabling. I highly doubt media from these companies won't pass a QA check with Netgear. I will take my chances with support if it comes down to a layer 1 issue.
Please let me know if there is a transceiver lockout or if there is a command I can issue which bypasses it such as what Cisco has with their NX-OS.
Thank you.
