auniquename
Jul 13, 2017Aspirant
traverse multiple vlans with a device that has no gateway
I have vlan 10, 20, 30 and 40 configured on 4 switches I have a device(let's call it "BBB") that does not have a default gateway (it's configured w/another route for remote access) Presently I c...
Retired_Member
Jul 13, 2017Hi auniquename
Welcome to the community!
According your description, it's work as design.
If host want to ping same VLAN device, it's no need forwarding by gateway, just running Layer-2 forwarding(mac table-based).
If host want to ping different VLAN device, it's need forwarding by gateway, need running Layer-3 forwarding(route table-based).
So you must set default gateway for device, then it can ping both same VLAN devcie and defferent VLAN device.
Hope it helps!
EricZ
NETGEAR employee
auniquename
Jul 14, 2017Aspirant
does the switch have intervlan routing capability?
GS752TPS
- JohnC_VJul 15, 2017NETGEAR Employee Retired
GS752TPS does not support intervlan routing capability. You might need to check intervlan routing on your router / firewall as it is the one that handles your VLAN gateways.
Hope this helps.
