auniquename
Jul 13, 2017Aspirant
traverse multiple vlans with a device that has no gateway
I have vlan 10, 20, 30 and 40 configured on 4 switches I have a device(let's call it "BBB") that does not have a default gateway (it's configured w/another route for remote access) Presently I c...
auniquename
Jul 14, 2017Aspirant
does the switch have intervlan routing capability?
GS752TPS
JohnC_V
Jul 15, 2017NETGEAR Employee Retired
GS752TPS does not support intervlan routing capability. You might need to check intervlan routing on your router / firewall as it is the one that handles your VLAN gateways.
Hope this helps.
