akira168
Mar 02, 2017Aspirant
Unable to add ports to LAG
Hi, I couldn't find any similar discussion. That's why I am asking. I have succeeded with setting up link aggregation using HP 5800AF, Allied Telesis CentreCom GS908M, Switch Blade x908, CentreC...
- Mar 07, 2017
Hi Akira,
Please try to configure same VLAN setting on LAG not only the physical port.
Actually the configuration only effect on LAG when physical port added into LAG.
Such as:
configure same VLAN PVID/VLAN member/VLAN Tag For the LAG which port 17/18 will add into.
DaneA
Mar 02, 2017NETGEAR Employee Retired
Hi akira168,
Welcome to the community! :)
Kindly answer the questions below.
a. Are ports 17 & 18 set as tagged (T) ports on VLAN 2004 and VLAN 3088?
b. Since you have set LACP (static mode disabled), is this also the same LAG settings configured on the Allied Telesis CentreCom GS908M? Kindly check and compare the Hash mode as well on the M7100-24X and Allied Telesis CentreCom GS908M switches.
c. Have you tried to reboot both switches and check if the LAG state shows Up?
DaneA
NETGEAR Community Team
akira168
Hi DaneA,
Thank you for your replying.
- Are ports 17 & 18 set as tagged (T) ports on VLAN 2004 and VLAN 3088?
Correct.
- Since you have set LACP (static mode disabled), is this also the same LAG settings configured on the Allied Telesis CentreCom GS908M? Kindly check and compare the Hash mode as well on the M7100-24X and Allied Telesis CentreCom GS908M switches.
I have tried the both of disabled static mode and enable on M7100-24X. But no luck. Also I have tried all the 7 Hash modes. It is quite same. When I add the port into a LAG, the connectivity is lost. As reference, I copy and paste the configuration of Allied Telesis CentreCom GS908M below.
Manager 3tkdtest8hub01> show config dynamic=
# SYSTEM configuration
set system name=3tkdtest8hub01
# CONSOLE configuration
set console timeout=0
# VLAN configuration
create vlan=vlan2004 vid=2004
add vlan=vlan2004 port=1-2 frame=tagged
create vlan=vlan3088 vid=3088
add vlan=vlan3088 port=1-2 frame=tagged
# IP configuration
add ip interface=vlan3088 ipaddress=192.168.88.50 mask=255.255.255.0 gateway=192.168.88.254
# STATIC MAC configuration
# SWITCH configuration
set switch port=1 acceptable=vlan
set switch port=2 acceptable=vlan
# TRUNK configuration
create switch trunk=uplink port=1-2 speed=1000m
# MIRROR configuration
# IGMPSNOOPING configuration
# PORT LIMITATION configuration
# PORT AUTHENTICATION configuration
# ACCESS FILTER configuration
# TELNET configuration
# FTP configuration
# NTP configuration
enable ntp
add ntp peer=192.168.5.242
# HTTP configuration
# LOG configuration
# SNMP configuration
# QOS configuration
# LOOP DETECTION configuration
# STORM DETECTION configuration
# EPSR Transit/Aware configuration
# MLDSNOOPING configuration
Actually it is pinging without a LAG.
C:\Users\G10092>ping 192.168.88.50
192.168.88.50 に ping を送信しています 32 バイトのデータ:
192.168.88.50 からの応答: バイト数 =32 時間 =16ms TTL=253
192.168.88.50 からの応答: バイト数 =32 時間 =2ms TTL=253
192.168.88.50 の ping 統計:
パケット数: 送信 = 4、受信 = 4、損失 = 0 (0% の損失)、
ラウンド トリップの概算時間 (ミリ秒):
最小 = 2ms、最大 = 16ms、平均 = 5ms
- Have you tried to reboot both switches and check if the LAG state shows Up?
I can only reboot Allied Telesis CentreCom GS908M. It is very difficult to reboot M7100-24X because it is in production in our company.
Best regards,
