akira168
Mar 02, 2017Aspirant
Unable to add ports to LAG
Hi, I couldn't find any similar discussion. That's why I am asking. I have succeeded with setting up link aggregation using HP 5800AF, Allied Telesis CentreCom GS908M, Switch Blade x908, CentreC...
- Mar 07, 2017
Hi Akira,
Please try to configure same VLAN setting on LAG not only the physical port.
Actually the configuration only effect on LAG when physical port added into LAG.
Such as:
configure same VLAN PVID/VLAN member/VLAN Tag For the LAG which port 17/18 will add into.
akira168
Mar 07, 2017Aspirant
Hi Jedi_Exile,
Thank you for your comments.
>1. Add only 1 member port on both switch to the LAG and then check if the LAG status is up.
The both switches are connected without LAG setting. They are perfectly fine. When the LAG setting is enabled on the Netgear switch, the connectivity between them is lost. I have tried all kinds of the settings such as Admin Mode, Link Trap, STP Moe, Static Mode and Hash Mode.
It cannot go to 2.
Do you think I missed something?
Best regards,
DanielZhang
Mar 07, 2017NETGEAR Expert
Hi Akira,
Such as:
- akira168Mar 07, 2017Aspirant
Hi Daniel_Z,
Thank you for your advice.
Even though I have changed the VLAN settings of the lag_3, the situation is still same.
Whenever the ports are added to the LAG, the connectivity is lost.
Please let me know if I made any mistake about the settings.
Best regards,
