akira168's avatar
akira168
Unable to add ports to LAG
Hi,   I couldn't find any similar discussion. That's why I am asking. I have succeeded with setting up link aggregation using HP 5800AF, Allied Telesis CentreCom GS908M, Switch Blade x908, CentreC...
  • DanielZhang's avatar
    DanielZhang
    Mar 07, 2017
    Hi Akira,
    Please try to configure same VLAN setting on LAG not only the physical port.
    Actually the configuration only effect on LAG when physical port added into LAG.
    Such as:
    configure same VLAN PVID/VLAN member/VLAN Tag For the LAG which port 17/18 will add into.
ProSupport for Business
