yoda
Jan 23, 2018Follower
Unable to disable routing on a GSM7224v2
I am unable to disable routing in a GSM7224v2 (Firmware 8.0.1.47). The gui hangs (looses connection) and when I fix it manually using serial cable. The Web-GUI shows 0.0.0.0 when routing is disabled ...
DaneA
Jan 29, 2018NETGEAR Employee Retired
I just want to follow-up on this. Were you able to perform the steps provided? If yes, what is the result?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
