Simon1978's avatar
Simon1978
unable to get CAM Table from GSM7252PS
I'm unable to get the CAM Table via snmp(dot1dTpFdbTable). Other snmp queries work. public@vlan doesn't work either.
  • Retired_Member's avatar
    Retired_Member
    Apr 20, 2017
    Hi Simon1978,
    Welcome to the community! Smiley Happy
    Please use MIB node 'dot1qtpFdbTable' instead.
    EricZ
    NETGEAR employee
    Retired_Member
    Hi Simon1978,
    EricZ
    NETGEAR employee
    • Simon1978's avatar
      Simon1978
      Hi,
      Thanks for the tip! The index-value in that table was confusing at first. But now I get it. The first value is the vlan number and the following numbers are the mac-address in decimal.
      Simon
        Retired_Member
        Hi Simon1978,
        Correct!
        With regard to resolve your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
        EricZ
        NETGEAR Employee
ProSupport for Business
