malacore
Jul 01, 2024Aspirant
Unable To Load Firmware On GSM7328Sv2
I was recently gifted a GSM7328Sv2 that was not factory reset before being given to me. I did not have the credentials for the switch so I pressed the factory reset button, but now there is no firmwa...
schumaku
Jul 01, 2024Guru - Experienced User
Start about here .... with tftp
- malacoreJul 01, 2024Aspirant
How do I utilize TFTP? I can only access the Boot Menu via serial cable. These are the options. Thanks!
Boot Menu
Options available
1 - Start operational code
2 - Change baud rate
3 - Retrieve event log using XMODEM
4 - Load new operational code using XMODEM
5 - Load new operational code using USB
6 - Display operational code vital product data
7 - File system directory listing
8 - Update boot code
9 - Delete backup image
10 - Reset the system
11 - Restore configuration to factory defaults (delete config files)
12 - Activate Backup Image
13 - Password Recovery Procedure
14 - Upload a file through XMODEM
15 - Download a file through XMODEM- schumakuJul 02, 2024Guru - Experienced User
So no other options ... XMODEM or USB copy (FAT16 or FAT32 file system required) the -correct- image over a serial line, but not before setting the highest baud rate available on the switch. FMI: here (read the full thread please on a similar switch model).
