riufaan's avatar
riufaan
Unable to ping second gateway. (GS752tp)
I have 4 Vlan created in my switch. Vlan: 80, 100, 110, 111
Vlan 80 is used for VOIP (IP 192.168.73.2)
Vlan 100 is used for local domain network (192.168.47.200)
Vlan 110 is used for staff wifi (192.168.10.2)
Vlan 111 is used for guest wifi (172.16.2.200)
My problem is that i cannot  connect to the my voip gateway 192.168.73.254. When i tried using the IPX-2500 i can ping to internet gatway 192.168.47.254 but it fails to connect 192.168.73.254
Port details:
g2 internet gateway (PVID: 100)
g11 VOIP gateway (PVID: 80)
g43 staff wifi (PVID: 110)
g46 IPX-2500 Lan (PVID: 100)
g47 IPX-2500 WAN (PVID: 80)
g48 guest wifi (PVID: 111)
Here is my runing config file
0x4E470x010x00gs7xxtp_p 6.0.1.16 0x000000000x00000000000000
config-file-header
Main_Switch_1
v6.0.1.16 / RNG60_760_045
CLI v1.0
set system mode router
qos active
policy-based-vlans inactive
lacp system-priority 32768
vlan database
vlan 2-3,80,100,110-111,500
exit
voice vlan oui-table add 0001e3 SIEMENS
voice vlan oui-table add 00036b CISCO1
voice vlan oui-table add 00040d AVAYA1
voice vlan oui-table add 000fe2 H3C
voice vlan oui-table add 001243 CISCO2
voice vlan oui-table add 001b4f AVAYA2
voice vlan oui-table add 0060b9 NITSUKO
voice vlan oui-table add 00d01e PINTEL
voice vlan oui-table add 00e075 VERILINK
voice vlan oui-table add 00e0bb 3COM
priority-queue out num-of-queues 0
hostname Main_Switch_1
snmp-server engineID local 8000005903003333333333
snmp-server location "IT Office"
snmp-server community private rw view Default
snmp-server community public ro view Default
snmp-server group default v3 noauth notify Default read Default write Default
snmp-server group default v3 auth notify Default read Default write Default
snmp-server group default v3 priv notify Default read Default write Default
snmp-server user admin default v3
service cpu-counters
interface vlan 1
no ip address dhcp
interface vlan 2
name "Voice VLAN"
interface vlan 3
name "Auto Video VLAN"
interface vlan 80
name VOIP
ip address 192.168.73.2 255.255.255.0
interface vlan 100
name Private
ip address 192.168.47.200 255.255.254.0
ipv6 address autoconfig
interface vlan 110
name Staff
ip address 192.168.10.2 255.255.255.0
interface vlan 111
name Guest
ip address 172.16.2.200 255.255.240.0
interface gigabitethernet1
lacp timeout short
lacp port-priority 128
switchport general allowed vlan add 80,110 tagged
switchport general allowed vlan add 100 untagged
switchport general pvid 100
interface gigabitethernet2
lacp timeout short
switchport general allowed vlan add 80 tagged
interface gigabitethernet3
lacp timeout short
interface gigabitethernet4
lacp timeout short
interface gigabitethernet5
lacp timeout short
interface gigabitethernet6
lacp timeout short
interface gigabitethernet7
lacp timeout short
interface gigabitethernet8
lacp timeout short
interface gigabitethernet9
lacp timeout short
switchport general allowed vlan add 100,110 untagged
interface gigabitethernet10
lacp timeout short
interface gigabitethernet11
lacp timeout short
switchport general pvid 80
interface gigabitethernet12
lacp timeout short
interface gigabitethernet13
lacp timeout short
interface gigabitethernet14
lacp timeout short
interface gigabitethernet15
lacp timeout short
interface gigabitethernet16
lacp timeout short
interface gigabitethernet17
lacp timeout short
interface gigabitethernet18
lacp timeout short
interface gigabitethernet19
lacp timeout short
interface gigabitethernet20
lacp timeout short
interface gigabitethernet21
lacp timeout short
interface gigabitethernet22
lacp timeout short
interface gigabitethernet23
lacp timeout short
interface gigabitethernet24
lacp timeout short
interface gigabitethernet25
lacp timeout short
interface gigabitethernet26
lacp timeout short
interface gigabitethernet27
lacp timeout short
interface gigabitethernet28
lacp timeout short
interface gigabitethernet29
lacp timeout short
interface gigabitethernet30
lacp timeout short
interface gigabitethernet31
lacp timeout short
interface gigabitethernet32
lacp timeout short
interface gigabitethernet33
lacp timeout short
interface gigabitethernet34
lacp timeout short
interface gigabitethernet35
lacp timeout short
interface gigabitethernet36
lacp timeout short
switchport general allowed vlan add 500 tagged
interface gigabitethernet37
lacp timeout short
interface gigabitethernet38
lacp timeout short
interface gigabitethernet39
lacp timeout short
interface gigabitethernet40
lacp timeout short
switchport general allowed vlan add 111 untagged
switchport general pvid 111
interface gigabitethernet41
lacp timeout short
interface gigabitethernet42
lacp timeout short
interface gigabitethernet43
lacp timeout short
switchport general allowed vlan add 110 untagged
switchport general pvid 110
interface gigabitethernet44
lacp timeout short
interface gigabitethernet45
lacp timeout short
interface gigabitethernet46
lacp timeout short
interface gigabitethernet47
lacp timeout short
switchport general allowed vlan add 100,111 untagged
interface gigabitethernet48
lacp timeout short
interface gigabitethernet49
lacp timeout short
switchport general allowed vlan add 80,100,110-111 tagged
switchport general pvid 201
interface gigabitethernet50
lacp timeout short
switchport general pvid 202
interface gigabitethernet51
lacp timeout short
switchport general pvid 203
interface gigabitethernet52
lacp timeout short
switchport general pvid 204
interface Port-channel1
exit
ip route 192.168.73.0 /24 192.168.73.254
snmp-server set rlManagementIpIfindex rlManagementIpIfindex 100099
snmp-server set rlManagementIpv4 rlManagementIpv4 192.168.47.200
Here is my rout table and arp
arp
Need help as soon as possible.
Thank you.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi riufaan,
    It might be possible that the ping reaches the 192.168.73.254 but there is no route going back.  Kindly check if there is a static route configured in the VoIP gateway that should be coming from the VoIP gateway itself going to the IPX-2500.
    DaneA
    NETGEAR Community Team
    • DaneA's avatar
      DaneA
      riufaan,
      I just want to follow-up on this.  Let us know if you have further questions.
      DaneA
ProSupport for Business
