EA1DDO
Apr 06, 2013Aspirant
Unstable IP Camera connection - GSM7224R
Hi all,
Using a switch GSM7224R for CCTV, with IP cameras and a NVR (Network Video Recorder), if I leave the switch with default settings, all works flawless.
But when I create port-based VLANs, the connection between the IP Caremra and the NVR becomes unstable. Sometimes works, sometimes disconnects.
This is the error I get at the NVR;
When the NVR detects the IP Camera correctly:
Then, the connections breaks itself:
With default switch configurations (VLAN1 default) I get no errors, so i understand that the VLAN is affecting in some way the connection...
The VLANs are port-based with different subnets, all ports are untagged:
So, the question is if anyone knows what is this happening?
What else I need to set on the VLAN to work flawless?
Thank you
Regards, Maximo
No RepliesBe the first to reply
