carlos1's avatar
carlos1
upgrading firmware on stack with two GSM7328FS
Hello Fellows!!!
I have a stack switch with two switches GSM7328FS.
I want to upgrade the firmware in both switches to the latest version 8.0.3.34.
I did the following :
1-I disconected the second switch (slave) from the stack for upgrading the firmware.
2-I reset the switch to its default configuration following the procedure shown in the documentation
After that, the switch continue showing in its display the number 2 as if it was connected to the stack and I can´t connect to the switch.
¿Which is the problem?
¿What did I wrong so the switch never go to its original state (default configuration)?
¿Which is the best way to upgrade this stack?
Thanks in advance, Carlos.
No RepliesBe the first to reply
ProSupport for Business
