MCuddy
Feb 01, 2017Follower
Upgrading from GS752TP to M4300 - Getting VLANs set up
I have a network with several GS servies switches and one non-netgear firewall/Router. I have a VOIP Phone system and a data network Voice IPs are served via DHCP on VLAN 2 via one port on the Rout...
JohnRo
Feb 03, 2017NETGEAR Employee Retired
Hi MCuddy,
Welcome to the community!
That is odd, does this setup work fine on the GS switches? What firmware version do you have on the M4300?
Thanks,
- JohnRoFeb 06, 2017NETGEAR Employee Retired
Hi MCuddy,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
