michael1io's avatar
michael1io
Uplink configuration with AX742 module
Hi all,
can I configure with Netgear AX742 a uplink port also or is it only for stacking? I asking because we've two Netgear switches which are not compatible for stacking regarding the used firmware.
Thanks,
Michael
  • Hi DaneA,
    after a discussion with Netgear support, it's not possible to use it for uplinks. There is no ethernet standard implemented.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi michael1io,
    I think its possible.  Make sure that the you will be using the compatible cabling type.  Refer to the image below:
    DaneA
    NETGEAR Community Team
    • michael1io's avatar
      michael1io
      Hi DaneA,
      • DaneA's avatar
        DaneA
        Hi michael1io,
        Thank you for sharing this relevant information here in the community.  Now its clear that the AX742 module is not possible to be use for uplinks because it does not have an Ethernet standard.
        Cheers,
        DaneA
ProSupport for Business
