jameswiltshire
Jun 06, 2019Aspirant
VLAN between different subnets
Hi, I`m trying to connect to a vlan at a partners site but struggling and could do with some help. Site 1 DrayTek 3900 Router Netgear M4100-50G-POE+ IP address range: 10.0.10.1/24, VLAN 1...
tagme
Jun 07, 2019Aspirant
Hi, what you need to do is just create a route entry on each side pointing to the other network with the routers outside address as a next hop. Do this over the untagged link and define a transder network like 192.168.168.0/24
Example
router site 1
IP route 10.23.31.0 255.255.255.0 192.168.168.10 (WAN address of site 2)
router site 2
IP route 10.0.10.1 255.255.255.0 192.168.168.20 (WAN address of site 1)
hope this helps
