Thanatos889
Aug 23, 2017Aspirant
VLAN Configuration between Netgear and Unifi
I am reaching out in the hope that somebody can assist me with this. Trying to get more coverage in our existing office block by allowing devices to roam om diffrent AP'...
Thanatos889
Aug 24, 2017Aspirant
Hi Man ,
Yes currently there is no vlan's setup this would need to be done from scratch.
Hopchen
Aug 24, 2017Prodigy
Cheers sounds good!
That would be easy enough I think - on your setup (granted your other switches can do VLANs as well). Acutually, you don't need to do a whole lot with that VLAN setup. Just a question.
How are these two "buildings" connecting to each other? Is there a cable from one switch - on one side, to other side or? In other words, do you have a more visible topology?
Thanks
