Thanatos889
Aug 23, 2017Aspirant
VLAN Configuration between Netgear and Unifi
I am reaching out in the hope that somebody can assist me with this. Trying to get more coverage in our existing office block by allowing devices to roam om diffrent AP'...
Redento
Aug 25, 2017Apprentice
Sorry don't understand the problem.
You must add all the AP in VLAN 1, that because Unifi AP need to communicate on VLAN1 whit the Controller.
Then, you have to set VLAN by SSID.
Ex:
SSID1: VLAN 10 LSA
SSID2: VLAN 11 LSA-Guest
SSID3: VLAN 12 LSP
- HopchenAug 25, 2017Prodigy
I think that the two server rooms/networks must be separated? I am not 100 % sure - which is why I asked him. If that is the case, then he will need some VLAN seperation. The controller could easily be cloud based, who knows :)
But if all APs are controlled by the same LAN controller and layer 2 separation is not strictly necessary, then yes, you are right - leave the VLAN situation alone.
