BKarrenstein
Feb 02, 2024Aspirant
VLAN configuration with active AutoVoip
Hello,
i have few M4300. I have configured AutoVoip for the telephones and telephone system. Everything works smoothly. Now I need to add a virtual server to the same VLAN as the phones. This server does not have a MAC address with the same OUI as the telephone hardware. Normally I would now add a port to which the VM is connected to the VLAN.
PVID: 50 - VLAN-Member: untagged.
This works for all other VLANs, but not for the VLAN that AutoVoip uses. When I try to add the port manually to VLAN 50, the following message appears:
VLAN participation change is not allowed on Auto-VoIP VLAN ( 50 )
How can I manually assign a port to an AutoVoip VLAN?
Since it is a VM, I cannot use the OUI from Hyper-V.
Thanks for your support
- Just by using a trunk connection and a tagged VLAN 50 I fear...
- schumakuGuru - Experienced UserJust by using a trunk connection and a tagged VLAN 50 I fear...
- BrianLNETGEAR Moderator
Hi BKarrenstein,
To accomplish this, you may want to manually tag all the phones in VLAN 50 and untag the VM (Virtual Server) and move away from using Auto-VoIP.
Kind regards,,
