damienginty
Apr 26, 2019Follower
VLAN Configuration
Hi - looking for some help or advice.......
Hi we have 2 x Netgear M7100-24x, these are connected to 2 HP5920af switches that are in an IRF stack (virtual switch) both using 4 ports in a bridge / link aggregation (2 cables from the M7100-24x to each of the HP5920af switches). The HP5920 are connected to 2 x HP5130Ei switches in exactly the same way as the Netgear M7100 switches.
Traffic flows through all switches as expected and the link/bridge aggregations appear to function on all switches. My problems start with the introduction of layer 2 VLANs. All switches have several VLANS setup. All bridge/link aggregations on the HP5920af are tagged in all VLANS. The Netgear M7100 and HP5130EI switches have their link/bridge aggregations tagged on all VLANS and a number of front ports are setup as access ports to each VLAN.
The HP switches pass VLAN traffic as expected e.g.
Equipment connected to Port 10 on VLAN 5 on HP5130 number one can see the equipment connected to Port 10 on VLAN 5 on the second HP 5130 (the HP5920 connect these 2 switches together) – happy days….. The same is not true on the Netgear M7100-24x switches, no matter what I try I cannot get traffic to go from a front port of the switch that is a member of only 1 VLAN through the link aggregation (tagged) to any other switch. I appreciate that I am probably doing something wrong with how Netgear switches are to be configured but I have no idea what.
I’m new to the Netgear world so any help or advice would be very much appreciated.
1 Reply
- DaneANETGEAR Employee Retired
Hi damienginty,
Let me share the article below. On the article below, 2 NETGEAR switches are used connected via a VLAN trunk link which is similar to your setup wherein the M7100-24x is connected via a LAG to the HP5920af switch:
How do I setup a VLAN trunk link between two NETGEAR switches?
Hope it helps.
DaneA
NETGEAR Community Team
