Reto1234
Feb 28, 2023Aspirant
VLAN Problem on MS510TX Switch
Hi there
Probably I'm doing something wrong. I try to to create an additional VLAN and that is not working as expected. I added a new VLAN ID 100, but as soon as I Set in the VLAN Membership the two ports with VLAN ID 100 to untagged and remove them in VLAN 1, they stop being able to ping themselves.
In the other hand as soon as I add VLAN 1 again (together with VLAN 100), the ping work like a charm. But what I want, is that people from the VLAN 100 cannot access devices on VLAN 1.
Maybe someone can help?
Model: MS510TX 8-Port
Software-Version: 6.7.0.30
- Reto1234Aspirant
I solved the problem, by assigning in the PVID Configuration to the ports the same PVID than the VLAN ID.
- schumakuGuru - Experienced UserThe poet PVID does define the VLAN untagged frames flowing into a port are assigned to. Mandatory for any kind of access port. It does not magically follow the untagged port definition.
- Reto1234Aspirant
Thank you very much for your reply. Another question I have at the moment is, how to configure the switch, if I have a Unifi AccessPoint that needs access to both of the vlans. Any idea?
