dominiccoombe
Aug 17, 2018Aspirant
vlan routing and you have other Netgear switches connected
Do you need to turn on vlan routing on all switches connected on same lan or do you only need to turn it on one of the switches Thanks Dominix
- Aug 19, 2018
Hi dominiccoombe,
Welcome to the community! :)
For example: Let say you have an M4300 switch as Switch 01 and another switch which is an M4100 switch as Switch 02. Switch 01 is directly connected to Switch 02. In this setup, be reminded that you just need to configure VLAN Routing on Switch 01 and do not enable VLAN routing on Switch 02 because that is already being taken care of by Switch 01. Then, for each VLAN you require on Switch 02, you must create that VLAN manually. Make sure to set the untagged members and PVID accordingly. On the uplink port (between Switch 01 and Switch 02), set the port as tagged (T) in each VLAN which must communicate from Switch 02 to Switch 01 (or vice versa) and also to the router.
DaneA
NETGEAR Community Team
DaneA
Aug 19, 2018NETGEAR Employee Retired
Hi dominiccoombe,
DaneA
DaneA
As a follow-up, let me share these articles below as reference guides:
VLAN Routing on Smart Switches
Setting up VLAN Routing on a NETGEAR Smart Switch
DaneA
