Drakecoldwinter
Aug 14, 2024Tutor
VLAN Routing Help
I have an old FSM726v3 switch. I would like to create 2 Vlans, one for my computers vlan1 (192.168.1.x) and another vlan200 (192.168.200.x) for a couple of crypto miners. I defined both vlans and did the port PVID configuration. Ports 15 and 16 route to VLAN200
Now I would like that the VLAN200 can't access the VLAN1, but both VLANs should access internet. My internet is on 192.168.1.1. Don't know how to do this part, also VLAN1 should see VLAN200
The problem I have is that on the routing page I can only see IP and ARP menus and under IP there is only statistics, I can see anything to activate the routing (checked online) why I'm missing the routing options ?
How should I properly configure everything ? and why I'm missing the routing menus ?
Thanks a lot
I found on internet it's a L2 switch and I need a L3 switch to be able to route between VLANs, con currently I can't setup the VLans just with the switch I'll need some extra hardware (router)
- PDAHazzardAspirant
I have a FSM7328PS Layer 3 Managed Switch and I still can't get Inter VLAN routing working. Is there anyone who can help me out?
- ErwinLNETGEAR Moderator
Hello PDAHazzard
And welcome to the NETGEAR Community! 🙂
You may want to check the link below for Inter VLAN routing.
https://www.downloads.netgear.com/files/7000_Web_UM.pdf
Have a lovely day,
Erwin
Netgear Team
Hello Drakecoldwinter
If I may ask do you have DHCP server for both VLANs? If yes, you may just member the port where the DHCP server is connected on the switch. Make sure the port membership of each ports are added to respective VLAN and removed as well from respective VLAN. Also the PVID of each port should be the same as the VLAN ID where they are a member for VLAN? Now for the for the permissions and restrictions of access you may need to configure ACL on ports. You may chech pages 610-612 from the link below for the configuration.
Have a lovely day,
Erwin
Netgear Team
