PAiSteve
Apr 23, 2022Follower
vLan Tagging won't stick, changes to back to untagged immediately
Trying to setup interface 49 as a trunk, when I Tag the port, the switch immediately changes it to Untagged. Below is my current config ------------------------------- !Current Configurati...
DaneA
Apr 28, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
I suggest to activate image 2 (if ever image 1 is currently the active image). Once image 2 is activated, make sure to update the firmware on it. Then, try again to configure interface 49 as a tagged port. Observe if the same problem will occur.
DaneA
NETGEAR Community Team
