mattstannard
Feb 16, 2017Aspirant
VLAN Trunking across multiple GS748T (and other switches)
Hi, We have a setup with a number of Netgear switches (two are GS748Tv5) and I want to create a VLAN, let's say 10 which is present on both switches. What I want is ports 1,2,3 and 4 on Switc...
Carl_z
Feb 17, 2017NETGEAR Expert
Hi mattstannard,
You configuration seems all right but port pvid not sure.
Can you help to check port pvid for ports (1,2,3 and 4) on Switch A and (5,6,7 and 8) Switch B. If not 10 please change it to 10.
We can change port pvid at "Switching>vlan>Port PVID Configuration"
Any result keep us posted.
Regards
Carl
Netgear Employee
mattstannard
Feb 17, 2017Aspirant
Hi Carl,
Thank you for replying so promptly.
Okay, so I've made a test VLAN 5
Switch A:
Port 39 goes to Switch B, and the one port I want to be a member of VLAN 5 on Switch A is port 44
I take port 44 out of the default VLAN 1 (but not port 39)
As where I am managing it from is plugged into Switch A, I can no longer see the device on Port 44 at this point, which is what I would expect.
Looking at the PVID Config:
Port 44 has a Configured PVID of 1, Current PVID of 1, VLAN Member of 5 - should the PVID be 5 and VLAN tag of none (should it be 5?)
Port 39 has a Configured PVID of 1, Current PVID of 1, VLAN Member of 1,5, and VLAN tag of 5 - I want this to still be in VLAN 1
On switch B
Same VLAN setup:
Then on the VLAN side, port 48 is the port to Switch A (tagged) and I want ports 1 and ports 6 in VLAN 5:
The PVID Configuration is as follows:
Are you able to suggest what changes I need to make?
Many thanks
M
