netarco's avatar
netarco
Follower
Aug 27, 2015
voice quality not good on avaya 5610 voip phones, switch gs752tp
hello, the gs752tp switch has the voice and data vlan, the vlans are working the way they should. avaya 5610 phones getting config and ip from voice vlan, pc getting a differnet subnet ip from default vlan. The voice quality is not good on some phones old and new, I enabled auto-voip on the switch, will have end user test tomorrow. does qos need to be setup as well, I thought this was a must set, but maybe not with newer switches.
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi netarco,
    It appears that you have already reached out to Netgear Support regarding your concern.  The case number is still open and you were advised by the support expert to check the IP phone(s) on the remote location.  Just kindly contact Netgear Support then update the support expert who is currently assisting you if ever you were done checking the IP phone(s) on the remote location.
    Also, I just want to share these links below.  Kindly read it and it might help:
    https://community.netgear.com/t5/Smart-Plus-Click-Switches/Proper-QoS-for-SIP-VOIP-with-FS728TP/td-p/180367
    QoS on Netgear Switches
    Welocome to the community! :smileyhappy:
    DaneA
    Netgear Community Team
ProSupport for Business
