agbn's avatar
agbn
VRRP configuration
Hi,
Please help me to configure vrrp on M4350 with multiple vlan .
Thank you
  • schumaku's avatar
    schumaku
    Your schema does show a stacked pair of two M4350, and a set of GS7xx PoE switches in a combination (like a poor-men's-stack), each with a redundant set of connections in a LAG.
    Don't want to start a philosophic discussion on stacking vs. MLAG however:
    What for do you plan to use VRRP for? Any security appliances or routers for handling multiple Internet connections around this for example not on the schema?
ProSupport for Business
