malamaka's avatar
malamaka
Follower
Feb 01, 2019
Want to bond two licensed WiFi links
Hi,
I want to bond two licensed wifi links together where each is now giving 500 mbps, I want a 1 gig link.
What do  you recommend using and how?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi malamaka,
    Welcome to the community! :)
    You mentioned "wifi links" -  there is no option to bond wifi links.  It could be that you are referring to bond ethernet links on managed switches.
    I recommend you the M4300 series switches.  For more information, kindly access the link below:
    M4300 Intelligent Edge Series
    Click also on the link below to check other NETGEAR ProSAFE Switches that might fit your network requirements:
    NETGEAR Switch Selector
    DaneA
    NETGEAR Community Team
  • schumaku's avatar
    schumaku
    Assuming both wireless bridges have standard Ethernet interfaces, you can deploy any kind of switches supporting LAG (Link Aggregation Groups, bonding, ....) - even Smart Managed Plus switches or Smart Managed Pro switches could to the job. Head for dynamic LACP LAG ideally. Be aware you woj't get a full 1 Gb speed between the same systems (MAC addresses).
ProSupport for Business
