star0815's avatar
Dec 13, 2018
Web Config via Management VLAN but not pingable
Hi community,   It might be a simple task to enable ping replies on a M4300 but I am not getting it. I can access the switch via Web Config (HTTP) but unable to ping. Same management VLAN witho...
  • JohnC_V's avatar
    JohnC_V
    Dec 20, 2018
    star0815,
    I found out that you do have a "no ip icmp echo-reply" command that causes your switch not to respond to ping.
    You may just enable it by typing the command "ip icmp echo-reply".
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
