star0815
Dec 13, 2018Tutor
Web Config via Management VLAN but not pingable
Hi community,
It might be a simple task to enable ping replies on a M4300 but I am not getting it.
I can access the switch via Web Config (HTTP) but unable to ping. Same management VLAN witho...
- Dec 20, 2018
I found out that you do have a "no ip icmp echo-reply" command that causes your switch not to respond to ping.
You may just enable it by typing the command "ip icmp echo-reply".
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
star0815
Dec 20, 2018Tutor
Hi JohnC_V,
thanks for your reply.
Made some tests to identify the misconfiguration.
Ping from management station to switch is not working (no answer).
Reverse ping from switch to management station is working.
Nets are not routed, same VLAN and no firewalls in between.
Ping from directly connected uplink switch to this switch is not working, reverse is.
This switch is configured as stack unit "7" (the only unit in this stack config).
Uplink switch is connected via transceiver F24-NG-AXM761 on port 7/0/51.
Will send switch config via PM.
Thanks a lot!
JohnC_V
Dec 20, 2018NETGEAR Employee Retired
- star0815Dec 21, 2018Tutor
Hi JohnC_V,
works as expected, device is now pingable.
Which setting can cause "no ip icmp echo-reply"?
Have never accessed the switch via console and not intentionally disabled echo-replies.
Thanks a lot!
- JohnC_VDec 21, 2018NETGEAR Employee Retired
I don't think that there is a setting that will make the ICMP reply to be affected. Also, this is enabled by default. We all know that before we deploy the switch we need to test it first if we do have a connection or replies coming from it.
