star0815
Dec 13, 2018Tutor
Web Config via Management VLAN but not pingable
Hi community,
It might be a simple task to enable ping replies on a M4300 but I am not getting it.
I can access the switch via Web Config (HTTP) but unable to ping. Same management VLAN witho...
- Dec 20, 2018
I found out that you do have a "no ip icmp echo-reply" command that causes your switch not to respond to ping.
You may just enable it by typing the command "ip icmp echo-reply".
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
boe
Feb 09, 2026Luminary
I'm on version 12.0.19.15. I did a full reset and set it for DHCP. I can get to the unit via HTTP but can't get to it through ping. My old switches - 4300 - just on 12.0.19.10 are accessible.
Did you ever figure this out?
star0815
Feb 10, 2026Tutor
I guess.
Try Routing -> IP -> IP Configuration -> ICMP Echo Replies = Enable.
Or follow the solution by enabling via console.
Best regards.
