bjmango
Mar 27, 2018Aspirant
Which Switch Model support block port#443 traffic per switch port and through command lines
I am looking for a switch that supports. 1. Block/unblock the internet traffic from a certain port (ex.port443) through command line. 2. The traffic could be controled per switch port throught the ...
- Retired_MemberMar 28, 2018
Hi bjmango,
As port #443 is known protocol for HTTPs over TCP, we can block TCP protocol port=443 as below:
[Step1: create IP ACL rule, deny TCP destination port=443]
ip access-list test
deny tcp any any eq 443
permit ip any any
exit[Step2: binding IP ACL to interface 1/0/6]
interface 1/0/6
ip access-group test in 1
exitBesides: If you want only permit packet with port=443, deny other packet. We need change IP ACL rule as below:
permit tcp any any eq 443
deny ip any anyFor detailed configuration of IP ACL function, please refer to CLI User Manual for Manged Switch, refer to the link (page 940: IP Access Control List Commands).
Retired_Member
Mar 27, 2018Hi bjmango,
Welcome to the community!
All Netgear Fully Managed Switches support config IP ACL to block specific traffic with certain port(TCP/UDP port) per switch port by CLI command.
For all Netgear Fully Managed Switches list, please refer to link, then select Swtiches-->Fully Managed Switches.
Hope it helps!
EricZ
NETGEAR employee
bjmango
Mar 28, 2018Aspirant
Thanks EricZ, could you give me a CLI example that blocks then unblock the port 443 traffic against switch port6? Thank you very much!
Hi bjmango,
ip access-list test
permit ip any any
interface 1/0/6
- bjmangoMar 29, 2018Aspirant
Thanks a lot EricZ!
