RobLigt
Oct 24, 2022Tutor
XCM89P Daughter Card versus XCM89UP Daughter Card?
Hi, I wonder what the differences are between the "XCM89P Daughter Card" and the "XCM89UP Daughter Card" ? Both are add-ons for PoE (802.3af) and PoE+ (802.3at) functionality to XCM8948 or XCM89...
schumaku
Oct 25, 2022Guru - Experienced User
UPOE was a proprietary extension to PoE (802.3af) and PoE+ (802.3at) allowing to provide higher power rates to PoE PD supporting UPOE.This is what was additional on the XCM89UP card.
The usage of four pairs is required because the loss on two pairs is to high, the requirement applies to the standards conpliant PoE++ 802.3bt allowing 60 and 90 W.
