Itamartaver
Sep 20, 2016Follower
XS708E Jumbo Frames / Firmware-Update issue
Hello! Please, i have a XS708E and i need to put both switchs (the other one is a Cisco SG500-28) to work together. Wich is the best way to perform this kind of setup? Theres any trick to do this...
JohnRo
Sep 21, 2016NETGEAR Employee Retired
Hello Itamartaver,
Welcome to the community!
Are switches in the same room? Wel, you can daisy-chain the two switches. You will have to look at the configuration of both switches, see if you want to pass VLANs on both of the switches. Do you have a diagram or a network plan?
Thanks,
