Itamartaver
Sep 20, 2016Follower
XS708E Jumbo Frames / Firmware-Update issue
Hello! Please, i have a XS708E and i need to put both switchs (the other one is a Cisco SG500-28) to work together. Wich is the best way to perform this kind of setup? Theres any trick to do this...
DaneA
Sep 25, 2016NETGEAR Employee Retired
Hi Itamartaver,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- fofwisdomDec 18, 2016Aspirant
I have simlar problem at XS708Ev2
- DaneADec 19, 2016NETGEAR Employee Retired
Hi fofwisdom,
Welcome to the community! :)
Kindly answer the questions below:
a. Did you try to perform a factory reset on the XS708Ev2 then check if same problem occurs?
b. How is everything connected? It would be best if you post a screenshot or image (.jpg or .png file) of your detailed network setup.
DaneA
- fofwisdomDec 19, 2016Aspirant
- May times to factory default.
- Through all as XS708Ev2 communicate is dropped.
client - Switch trunk - XS708Ev2 trunk - XS708Ev2 (dropped)
XS708Ev2 under all client (dropped)
Screenshot attached my thread.
Thanks.
