Itamartaver
Sep 20, 2016Follower
XS708E Jumbo Frames / Firmware-Update issue
Hello! Please, i have a XS708E and i need to put both switchs (the other one is a Cisco SG500-28) to work together. Wich is the best way to perform this kind of setup? Theres any trick to do this...
fofwisdom
Dec 18, 2016Aspirant
I have simlar problem at XS708Ev2
DaneA
Dec 19, 2016NETGEAR Employee Retired
Hi fofwisdom,
Welcome to the community! :)
Kindly answer the questions below:
a. Did you try to perform a factory reset on the XS708Ev2 then check if same problem occurs?
b. How is everything connected? It would be best if you post a screenshot or image (.jpg or .png file) of your detailed network setup.
DaneA
NETGEAR Community Team
- fofwisdomDec 19, 2016Aspirant
- May times to factory default.
- Through all as XS708Ev2 communicate is dropped.
client - Switch trunk - XS708Ev2 trunk - XS708Ev2 (dropped)
XS708Ev2 under all client (dropped)
Screenshot attached my thread.
Thanks.
