thepp
May 12, 2016Follower
XS708E ports are half 100Mo and half 1000Mo
Hi all, I run a small production company and purchased a XS708E switch to connect our several editing stations and our NAS. It works great except for the fact that every other port is running at...
DaneA
May 12, 2016NETGEAR Employee Retired
Hi thepp,
Welcome to the community! :)
Let us isolate the problem. Kindly answer the questions below:
a. Is it possible for you to borrow a CAT5e or CAT6 ethernet cable so that you can try if same problem will occur using these ethernet cables?
b. What is the current firmware version of the XS708E switch?
c. Have you tried to perform a factory reset on the XS708E switch then check if same problem occurs?
DaneA
NETGEAR Community Team
