WebsterWebster
Aug 15, 2018Aspirant
XS716T and Jumbo Frame MTU
I actually have an XS716T but that model didn't appear in the drop-down list or models.
I am looking at Configuring jumbo frames on NETGEAR ProSAFE switches . It shows to set a jumbo frame MTU ...
schumaku
Aug 15, 2018Guru - Experienced User
The maximum frame size depends on the switch design and SoC in place. The XS708T, XS716T, XS728T, XS748T Data Sheet does (somewhat lazy) talk of Jumbo frame support "Up to 9K packet size" for the XS708T and the XS716T, and "Up to 10K packet size" for the XS728T and the XS748T (which don't have an ability to configure the max frame size per port).
The 9216 example (as shown on a top of the line witch with 12k frame support) is - while common - kind of a randomly chosen number to include whatever padding and the like.
bradleyv or LaurentMa can you shed some light about the slightly uncommon smaller 9198 here? An exact number on the data shet would make things clear, too.
- WebsterWebsterAug 22, 2018Aspirant
Should the 1G ports also have extra padding for frame headers? The original article I linked shows the 1G ports with an MTU of 1518.
Thanks
Webster
- schumakuAug 22, 2018Guru - Experienced User
While the XS716T has no GbE ports, in general, a basic Ethernet frame does start with 14 Bytes of Ethernet header, can take max 1500 Bytes of payload, and has a trailing four Bytes CRC ... this makes up the 1518 Bytes. It can be four Bytes more if 802.1q VLANs are in the play, and much more...
Rergards,-Kurt
I have no VLANs (and have no idea how to create or use one) so I should set the MTU to 1518 for the ports that will operate at 1G.
Thanks
