daveoy
Sep 26, 2018Aspirant
XS716T management vlan communication lost
hey there, I have a bit of a cunundrum.
i set up a vlan (id 3012) on my xs716t switch, and set port xg14 up on that vlan untagged. I gave the switch an IP and set the management vlan of the swi...
JohnC_V
Sep 28, 2018NETGEAR Employee Retired
Hi daveoy,
Welcome to our community! :)
Once you changed the management VLAN, you should also change the PVID of the port that you wanted to manage the switch. If you want port 1 to be your PC(Admin PC) that manages the configuration of the switch, you need to change the PVID to 3012 too. So that it will be a member of VLAN 3012. You may need to reset the switch to factory default setting or access the switch via console in order for you to set the management VLAN back to VLAN 1 and gain access to admin GUI.
VLAN aware devices are always configured as T or Tagged like APs, Smart Switches, Routers, VoIP, etc. and non-VLAN aware devices should always be assigned as U or Untagged like PC, Printers, Scanners, etc.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- daveoySep 28, 2018Aspirant
is setting the PVID somehow different than adding the port i want untagged on vlan 3012?
