Neoower
Oct 22, 2023Aspirant
XSM4328CV - M4350-24X4V - LACP goes down and switch becomes unresponsive
I just purchased the M4350-24X4V 10GB switch and ever since installing it I have been having a problem where the switch will stop sending LACP keepalives causing my LAG to my main switch to go down. ...
LaurentMa
Oct 23, 2023NETGEAR Expert
Hi Neoower ,
Sorry about this issue. What is your core, and do you know if you kept Auto-LAG enabled on the M4350 switch? It is enabled by default in Switching\LAG; maybe it is conflicting with your core configuration. Same for Auto-Trunk in Switching\VLAN\Advanced\VLAN Trunking.
Can you export the Tech Support file (Maintenance/Export/HTTP File Export/tech-support in the dropdown menu) and send it to [email protected]
We will see what is going wrong. Thank you,
- NeoowerOct 23, 2023Aspirant
The core is a Cisco 3750X. The uplinks between the cisco switch and the netgear switch are 10GB SFP DAS.
Auto LAG admin mode is disabled. Auto-Trunk Admin mode was enabled, I will disable that right now.
I have had a support case open for about a week with no movement (47727678). When I called in on Friday I was advised to email the proavdesign team which I did, but I still have not heard back. In the case is the show tech and I enabled logging to usb drive hoping to catch something when the switch locks up, those logs are on the case as well.
- LaurentMaOct 23, 2023NETGEAR Expert
Hi Neoower ,
Thank you, I have consulted your case and asked the team (Tech Support and ProAV Design) to get back to it now that we have crash logs in your ticket.
For now, can you please try the following:
- IT GUI, System\ISDP: Disable Admin Mode under Global Configuration, globally and click Apply then Save
- IT GUI, Switching\Multicast\IGMP Snooping\Interface Configuration: Select all interfaces and all LAGs, and configure Disable in Admin mode, click Apply and Save (you have configured IGMP for the VLANs already, so the interface config is conflicting with the VLAN config)
Can you report back, what is the frequency of the LAG going down and the switch becoming unresponsive?
Done!
It usually stays up for about a day or two. Looking at the logs on my cisco switch, I power cycled the netgear switch around 10 AM on the 21st and the switch locked up around 5AM on the 22nd.
Thank you!
