pma's avatar
pma
XSM7224S all LED's yellow
Hello,
We recently bought a XSM7224S, and when we powerup the switch the power LED remain yellow (not blinking), and the LED's of all ports are yellow too.
 We tried to connect to the switch with serial interface unsuccesfully with the command "screen /dev/ttyS0 9600,cs8,-ixon,-ixoff".
There is one green LED, which is the fan one, and the stack master and power 2 LED's are down (we have only one power supply)
Thanks in advance for your help.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi pma,
    Welcome to the community! :)
    Since you have gained access via the console port, kindly execute the command "clear config"on the privileged EXEC mode to factory reset the XSM7224S switch.  Then, check if it will boot up just fine as well as check the behavior of the LED lights.
    DaneA
    NETGEAR Community Team
    • pma's avatar
      pma
      Hi, thank you for your quick reply,
      But i cannot have any access through the consol port, and that's why I'm blocked and cannot configure the switch.
      Thanks in advance
      • DaneA's avatar
        DaneA
        Hi pma,
        Let us isolate the problem.  Kindly answer the questions below:
        a. Have you tried using another console cable as well as another PC to have console access?
        b. Have set the following settings to gain console access [baud rate: 9600bps / data bits: 8 / parity: none / stop bit: 1 / flow control: none]?
        c. The XSM7224S has a default IP address of 169.254.100.100 as per page 505 of the user manual here.  Kindly try to connect a PC directly to any LAN port of the XSM7224S then set a static IP address on the PC that is within the range of the default IP address of the XSM7224S and check if you will be able to access its web-GUI.  Are you able to access the web-GUI?
        Note: Kindly try to check if you get replies from the default IP address of the XSM7224S using the ping command via the command prompt.
        I look forward to your response.
        DaneA
ProSupport for Business
